It is currently Mon Jul 21, 2025 7:19 pm
 Post subject: Digital Scale
PostPosted: Mon Mar 10, 2008 7:20 pm
Looking for recommendations on a digital scale. How good a scale do I need? I can pick one up on e-bay for twenty buck w/ 1 gram accuracy or should I hold out for something better. Looking to weight parts and shellac and the like.
Peter
 Post subject: Re: Digital Scale
PostPosted: Mon Mar 10, 2008 7:33 pm
I bought one for about $35 from the Office Depot near me that also has 1 gram readings. For Shellac it's fine - it doens't reall matter if you mix up a 2lb cut or a 1.85lb cut. Sometimes when measuring small amounts of epoxy I wish it had .1gram readings but I get by - you must suffer for your art right!
David White, Toronto
PostPosted: Mon Mar 10, 2008 8:42 pm
I've got a little wee scale from an e-bay outfit that reads to 0.01 gram. Very handy with small amounts of epoxy and whatnot. The differences between bridge plates, braces and other parts is often a fraction of a gram, also, so it's great there, too. Can't imagine working without it... It only goes to 100 grams, but over that, I switch scales....
Cheap, too.
PostPosted: Mon Mar 10, 2008 8:54 pm
HF has a little portable one that folds up into a case, and it is often on sale for about $12 or $13. Seems to work fine. Has a tare set, weighs in grams and ounces to one decimal place.
PostPosted: Tue Mar 11, 2008 8:50 am
I have a Toyo 250 pocket scale that works just fine. It seems to be out of stock in most places at the moment. I costs about $40. I did a google search and found the following site: http://www.rightonscales.com/web/pocketscales/. There seems to be a very large number of options for small scales.
PostPosted: Tue Mar 11, 2008 10:22 am
Here's one you might be interested in.
http://www.saveonscales.com/product_pro ... eries.html
